Old 05-26-2009, 04:05 PM   #86 (permalink)
rjacob
rjacob's Avatar
2000 Honda Civic VP - '00 Civic VP
90 day: 40.41 mpg (US)
Originally Posted by 2005_rs View Post
It occurred to me that a combination of both ideas might work.
The existing cruise control could be used to hold the throttle position by building a pulse generator to feed the signal input. The cruise would recieve an unchanging signal, and would therefore hold the throttle steady. No cables or wires through the firewall.
I have been thinking the same thing. Have a pulse generator fooling the cruise control into thinking you are going at a steady speed. There could also be a switch that would control the inputs, one setting would feed the steady pulse, the other would feed the speed sensor output. This way it would work as either a cruise control, or a throttle lock.
One thing that I would be concerned about the steady pulse feed, would be if you hit the cruise button to bumb up the speed. It would try to go faster, but since the pulse would never increase, it might keep adding throttle until the pedal was floored.
GreenCarMPG.com
