Old 05-26-2009, 09:42 PM   #1 (permalink)
NeilBlanchard
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Swooping - technique for hills
Hello,
I've been having to try to deal with New England's (small and frequent) hills, and I think that I may have found a technique, that I'll dub "swooping". It is pretty simple really and is pretty much like how you have to bicycle.
As you near the bottom of a downhill, if you are then faced with going up another hill, I (put it back into gear if I have been coasting and) accelerate a little in the last bit and build up some speed to carry me up the hill. Since you have a little more speed, you can keep the use of the accelerator to a minimum and still crest the hill without slowing down traffic.
I used to try and coast up the hill as far as I felt comfortable, and then using the gas, but then you have to accelerate up hill -- which is just about the worst thing you can do for FE... So, swooping definitely works a lot better!
What do you think? How do you minimize FE losses on hills?
