Old 05-28-2009, 05:45 PM   #9 (permalink)
doviatt
doviatt's Avatar
Grey Goose - '89 Metro LSI 4 door hatch back
90 day: 59.36 mpg (US)
wyatt
Thanks for the info.
I've already got a good injector signal I used with my recent tach install.
I'll give it a try with the wheel spinning thing for VSS.
When I measured my green with yellow stripe wire with the engine on, it had 14 volts. That doesn't sound like what I'm looking for. Must be a different color on the '89?
Seems like I've read looking behind instrument panel for where spedo cable plugs in. Does this sound reasonable also?
Thanks, I'll start digging
Edit: my first sentence is unclear and just plain wrong. I used ignition coil -gnd for tach install but found the injector signal on the TB where it should be for the MPGuino hook up.
