Old 05-29-2009, 10:30 AM   #20 (permalink)
theunchosen
The thing about a Prius. . .for most people. . .
Is it won't go quickly if you ask it to. If I stomp My Del Sol to the floor it will go, screech the tires and the front end will bounce a little.
Driving even on ecomod is not ALWAYS about FE. Maybe it is for you guys but on occassions I love to go out and roll through the mountains with the gas mashed to the floor. I'll still get above 26 mpg doing this. . .while the prius if it does that gets sub 20. On the other hand I can crank 36-37 with light steady-state driving, with a few upcoming projects 54 might well be within range. . .
RH you could get a used Fit with AC. I'm sure there are some of those around somewhere(not from a dealer). If you could find a lightly used Fit from another consumer I'm sure you could pull them out for 12. The Fit gets alright gas mileage in stock state with moderately heavy driving, with light driving steady state, some cheap aero boosts, what reductions can be had, and maybe wheel skirts you can probably beat the Integ. . .
