Old 05-29-2009, 10:50 PM   #1493 (permalink)
dlaing
Corolla bandit - '05 Corolla CE
I'm really looking forward to seeing the new code.
The compiler will be optimizing all math with powers of 2 to be bit shifts, 1 clock cycle vs lots of cycles.
Because the ADC is going fast now, could we have the throttle and temperature checks happen in the time between current checks . You could put the temp and throttle into the interrupt when the current finishes. The ADC should easily be finished before the next current read. Then we can always check the current.
