Old 05-30-2009, 10:08 PM   #1498 (permalink)
dlaing
Corolla bandit - '05 Corolla CE
Maybe I can just send the software to that one place, but I don't know how to "commit" to send it. I don't see that as an option. Maybe people can look over the code and make sure everything seems basically OK. I think I need a new control section before test driving it, though. boohoo.
Paul, if you have already checked out the code, you should see the same files as here: /trunk - Open ReVolt - Trac
Then you move your code, c and project files, into the directory you want. Add the files to svn, and then commit your changes.
If this doesn't help, where are you running into problems?
