Old 05-31-2009, 01:45 AM   #1501 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
Originally Posted by dlaing View Post
Paul, if you have already checked out the code, you should see the same files as here: /trunk - Open ReVolt - Trac
Then you move your code, c and project files, into the directory you want. Add the files to svn, and then commit your changes.
If this doesn't help, where are you running into problems?
All I know is I have a bunch of new code that I'm supposed to "commit" to some thing so others can read it. I downloaded some program, so that when the downloaded program is running, if I right click on the software project, it gives various options. None of those options are called "commit", so I don't know how to "commit". If it seems like I have no idea what I'm talking about, it's because I have no idea what I'm talking about.
I finished drilling the five 5/16" holes in one of the copper heat spreaders. That's a total of drilling through 7.5" of solid copper. yuck. The rubbing alcohol really comes in handy for that.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
