Old 05-31-2009, 08:55 PM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
diy $2 lower stress bar
Here is about $2 in 1" conduit that has been custom fit to the control arm mount ends. The mount ends are cantilevered so this adds quite a bit of stiffness to the lower control arms. It is so cost effective that it is hard to justify NOT doing it Just need to be able to hammer and drill and cut, and I bent it by foot (mostly while it was still long). If you were paying attention before installing this, you should notice a significant difference afterwards, at least that has been my experience.
The key things are identifying the low spot(s), making about the right bend, then cutting both ends (a little long at first) and flattening one end and getting one hole in the right place in relation to the bend/low spot, then using that hole over the bolt readjust the angle if needed, then flatten the other end and with the first hole around the bolt, mark the second hole. I wound up bludgeoning the holes in with a 5/8 carbide masonry bit, you may have something nicer around I also flattened the ends with a mallet and held it flat against the concrete with a piece of wood.
