Old 06-01-2009, 09:40 PM   #4 (permalink)
gascort
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
Thanks for the links, guys. I'm definitely headed in the same direction as the guy in DCB's link; I definitely detect the missing fuel when I look at my fuel logs and can say that it's probably due to the injectors opening differently and needing different delays in the MPGuino to work.
That being said, I'm not enjoying significantly improved FE although I have no alternator, power steering, or a/c spinning when I remove the belt. I know there is energy being saved there, so I probably need to tackle the voltage issue. Thanks!
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
