Old 06-01-2009, 11:35 PM   #7 (permalink)
theunchosen
Yeah I had thought about this a little. The saw has trouble at low speeds unless you gun it to high rpm and then it can slowly coast down to lower than you can hold and cut. . .but I'm not at all certain if thats more a function of the blade or the engine.
Both are much less effective at low RPM I know for sure, but I can't help but wonder if the saw would be able to pull it out from a stop. Acceleration won't really be an issue(unless it won't) so I guess I'll just have to test it out first?
