Old 06-02-2009, 10:31 AM   #30 (permalink)
stevey_frac
Jalilah - '07 Cobalt LT
90 day: 40.57 mpg (US)
Hi,
I would only do a partial lower grill block -- you do need some air to get to the radiator! And if the lower outside "grills" are open, I would block/cover them. What does the space between the grill and the radiator look like -- is it open or (partially) closed?
You could do a test of wheel covers using tape, and if it works, then buy/make yourself some smooth wheel covers. You're starting with a pretty clean looking car, with a good overall shape.
The lower outside grills are closed. From the factory. The upper grill block actually dosen't cover right to both edges, and leaves a bit of room open on the right side.
The space between the grill and radiators is wide open, Like. Nothing there at all.
For the wheel covers i was looking at getting moonies from HubcapMike, but he wants around $150 for them, shipped to Canada, which seems a lot for hubcaps. I can almost buy new steel wheels for that. I'm trying to see if anyone around here sells them locally.
-Steve
