Old 06-03-2009, 06:13 AM   #4 (permalink)
hamsterpower
one of thOOOse people
twitchy - '98 civic dx + sir + ls
90 day: 33.35 mpg (US)
Originally Posted by wagonman76 View Post
Not sure what you're using now, but an 18" breaker bar will do wonders. Not so you can reef on it and break it off, but take it easy and it gives you an amazing amount of control that you can't get with a regular short ratchet. I removed an original sensor from a 93 Corsica a few years back like that.
I second this. in fact I think the longer the better for breaker bars. light pressure on a very long lever is much less likely to break off bolts than pounding on a short lever. if its not easy with an 18" bar slide a 3 foot long pipe over it. Just pull lightly on it though.
once its out put a little anti-seize on the threads of the new one.
Good luck.
