I bought an assembled
MPGUINO from you this week actually. I followed the directions online here and am wondering if the connector wires are touching since they sit so close together. but i even put liquid tape around the ends of each connector before i hooked everything up, then i tapped the wires close together with elect tape. I will remove the elect tape this morning. I was hoping that was just ghost voltage on the inj. what reading should i be getting on the vss hot or cold? I followed the directions for your 98 metro hook up. my hanes manual elect diagram says that the vss is the yellow green that i hooked up. Just not sure what to do at this point.
