Old 06-03-2009, 08:59 AM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Also understand that you did not "BUY" it from me, you made a donation. The number of hours that I've put in measured at the per unit level makes this a gift. If I were selling them it would be much more expensive, and you would have to go through someone else to talk to me
What in the wiring might be shorting out when you move it? The wiring is your department. Did you put the pins in the connector block on the mpguino end? I'm at a loss here.
