thank you for the help and responses this is a great forum. I will try to describe a little better. I am doing my best to describe. as for the pin connections I am speaking of the pre-assembled unit i received from a donation to dcb which i stated early on in this thread. so the connection to the unit has already been chosen by dcb. I did visit 2 different radio shacks nearby. They didn't have any compatible replacements. so I would like to buy anoth from dcb if possible. I am a residential electrician, so I am somewhat familiar with low voltage dc wire troubleshooting. I have traced all of the wires they have good continuity. I even soldered the wires to the female connector and insulated everything properly. I have used all of the wiring schematics provided for a 93 geo metro religiously following the diagrams and colors. I still get a gh reading when i remove the injector lead and vss lead.
