actually the wire arrangement demanded by the connector arrangement would ground out the injector because it is nearest to the black ground wire.(or create backfeed on the injector as well since it is also next to the 12V lead wire) If anything, the vss could have received 12v from the lead creating a backfeed of sorts. I will continue my quest tomorrow after work. Please throw any new thoughts my way.
