Old 06-04-2009, 03:00 PM   #4 (permalink)
DonR
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
I don't think anyone has ever done it. There has definitely been talk of it though.
How would you use it as a block heater?
When I park at work, my car faces west. When I leave work the sun is shining on the front of the car. This would heat up the coolant in the panel. If you had a very small pump, run off a secondary battery or a solar panel, to circulate the fluid back through the system it should help heat the block. Placement of the inlet & outlet for the panel would need to be thought over.
On the steel sheet note. The state has most people putting a steel sheet on the front of their car anyway. I pay about $55/car per year for the privilege. I wouldn't hold it on with velcro, mainly because my car's cooling system is on the line.
Don
