How did you hook up your kill switch? I was thinking about doing the same thing. I know I would do a lot more EOC if I didn't have to use the key to do it. My plan was to mount two switches by the e-brake (easy to rest my hand right there). One switch would be in-line with the "run" circuit, to kill the engine and then turn it back on immediately so my blinkers still work and I can bump-start. The second switch would be a "press and hold" style to start the engine back up if I didn't bump-start. Any comments or suggestions? I like to use the starter to start the engine from EOC as bump-starting, no matter the gear/speed, isn't the smoothest.
E85 ~$3.17/gal.
