run an injector cleaner and diesel fuel bug killer for a couple of weeks, each time run the fuel tank as low as possible to use all the old fuel, then turn the screw OUT(to lean) 1/8 at a time, drive for a day, turn again, drive for a day...until you become underpowered then go back to the previous days setting
driving slow is good for FE but dont take too long accelerating and getting up to speed
60psi rocks for FE
