Old 06-11-2009, 02:47 PM   #40 (permalink)
McTimson
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
hondo434, yes, I do drive the 93 Tercel, and I use hypermiling tactics. However, for the purpose of testing, driving habits would remain the same whether or not the magnet is on. If the magnets do work, then I should get even better mileage even with hypermiling methods being used. As long as you drive the same (i.e., drive for 20 miles at a constant 55MPH), then there should be a difference in the amount of gas used, if they are truly effective. Cruise control is perfect for this because it can be more accurate - my car does not have cruise, but I can keep a steady speed, especially on flat roads.
Anyway, some sort of testing like this needs to be done in order to claim that it is effective. It's easy to have a 'placebo effect' when performing a modification on your car - you want it to get better mileage, so you naturally drive a little slower without realizing it. Or, it could be warmer out that day, so there's a free MPG increase - it's hard to quantify how effective one modification is unless you perform a test on it.
