Old 06-11-2009, 08:35 PM   #13 (permalink)
Peter7307
With most a/c set ups the air is first sent over the a/c condenser to make it dry and also cold and then if needed it is sent through the heater matrix / core to add whatever heat is deemed necessary.
Many drivers want both warm air and dry air in a humid environment to defog windows etc.
Also auto a/c compressors are notoriously inefficient due to the operating rev range they are needed to work over.
If they were even close to the efficiency levels in household a/c units they would not last at speeds much above idle.
Pete.
