Old 06-12-2009, 08:56 AM   #10 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 39.65 mpg (US)
Behind the tire, make a long trailing edge that comes to a point. In front of the tire, either do nothing, or put a small rounded deflector that approximates the curve of a naca foil.
Between the front and rear tires, you can put in a catamaran which is a box between the wheels.
Nissan Versa Aeromods
