Old 02-22-2008, 11:32 AM   #28 (permalink)
NoCO2
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Civic DX
90 day: 33.29 mpg (US)
The point I think with the Pico-ITX system is if you are looking for a new computer, these are pretty inexpensive compared to comparable other ITX or ATX systems. Also note, that, if you are even the slightest bit computer savvy, you can install and use Ubuntu Linux which is the best distribution out right now in my opinion. In 6 years, you would probably have to upgrade your computer at least twice to keep up with just the windows operating system's, system requirements, however, I can almost guarantee that if you are using ubuntu, you will never need more system then you started with, even if you upgrade to the new release every 8 months. So keeping that system running for 6 years would not be completely un-realistic. Yea, you wouldn't see the savings for that much time, but still, 6 years to break even is better then never breaking even with another "less expensive" system.
