Old 06-13-2009, 01:10 PM   #11 (permalink)
NeilBlanchard
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi Christopher,
Where are the entry points? How will it be situated on the site -- do you have a site plan? How flat is the area where the footprint of the house will be -- total elevation change? What is the floor and the roof structure? Do you need to worry about earthquakes, hurricanes, tornadoes, fires, freezing winters, etc? Will you be using renewable energy for heat, domestic hot water, electricity? Do you want to incorporate gray water and/or rain water systems?
Those are darn big rooms! The structural span of the roof will be very tough, and you have to have enough pitch to make it work with the roofing material. I'm not sure that you will want the rooms to be that big -- they will just require a lot of walking? Your two bedrooms sound big enough together for a Great Room. I once was asked by clients to make a kitchen the was like 18' x 22' and it was simply too big to be efficient. Just because too small is no good, and a bit larger is fine; doesn't mean that gigantic is better! You want a "Goldilocks" design, I think...
