Old 02-22-2008, 02:40 PM   #5 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 70.97 mpg (US)
I wonder how they are getting around compressed air's inherent inefficiencies. A lot of heat is produced when air is compressed. On large compressors, this heat is usually removed with a heat exchanger at the output of the compressor, allowing them to store a greater quantity of room temperature compressed air rather then a lesser quantity of heated air. Then when the compressed air is expanded to room pressure, its temperature drops precipitouosly. That air heater they use at speeds over 35mph looks like a method to try to compensate for expansion cooling of their compressed air to increase their range. And if you talk to anyone in industry who runs a compressed air system, compressed air is not cheap to produce and can be one of a plant's larger electrical expenses.
aerocivic.com
