Old 06-15-2009, 10:31 PM   #120 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I just got the car off the charger for the night. The kill-a-watt recorded .48 kWh used. When I put the battery on the charger, the charger said the battery was still at 70%. So, I have tons of capacity left in the battery which is great! I think it can be safely said that my charger is fairly inefficient since the total capacity of the battery is only .9 kWh. Anyway, today's commute was pretty bad compared to normal (accident on the way home had things really backed up), so this is about as bad as it should get.
