Old 06-16-2009, 08:06 AM   #68 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by Geebee View Post
And for the average user in a series hybrid the ICE will rarely be used as it is range extending only....
Why do you think the series hybrid is unique in this case?!? A parallel range extender would only be used when needed too.
But if you build it in, then at least half of "the average user" will use it a LOT, and you have extra weight (motor + generator) to carry all the time. If it is a 5th wheel spring loaded thing you put in your tow hitch receiver for longer trips, it won't get used a lot (or if it plugs into the existing driveline somehow).
