Old 06-16-2009, 09:55 PM   #13 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
Originally Posted by beatr911 View Post
OOPS! Should've read the original post. Guess you did the gearing.
Well I still think you can reach 100 mpg. I picked up 5+ mpg on my Connie by lowering the fuel level in the float bowls about 10mm, effectively leaning all circuits. This may have other adverse affects on the main, but I almost never dip into the main circuits.
To do it better weld in a bung on the exhaust and install a cheap O2 sensor and monitor the voltage with an AFR gauge or a voltmeter. Adjust jetting, air orifices and mixture screws accordingly after doing good research on how your carbies work. This will get you pretty darn close and you won't spend $400 on a wide band set up.
Additionally, I'm considering using intake air heat to seasonally fine tune the carbs though I don't know how effective it will be with the CV carbs we have.
I think its possible for me to reach 100mpg too... i am very close
My carbs are much smaller. The stock float bowl height in my carbs is 17mm, and when i took the carbs out a few months ago to clean them, they were both exactly at 17mm. I dont think i'll be able to decrease it nearly as much as you did. I may only be able to go 3-5mm.
I dont think i ever use the main jets on my bike. In fact, most of my riding probably is influenced by the pilot jet and screw. Even on the highway, i dont think i go more than half throttle, even with the changed gearing.
Are you suggesting using a narrow band or wide band sensor? I have a few narrow band sensors laying around from various cars i have owned. The only wideband i have is in my 1984 Buick Grand National, and its a part of the FAST standalone ecu that i have in the car. All a narrow band + voltmeter will tell me though is whether or not my current mixture is stoichiometric. I can see your pint. The only problem is that the exhaust pipes on the ninja 250 are only 3/4" ID each (i just measured), so i would need to find a NB sensor small enough to fit.
Another thing is that in stock configuration, the Carbs on this bike are a hassle to work on.... because of the huge factory air box. If i were to replace the airbox with pods, it would make things much easier.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
