Old 06-16-2009, 10:15 PM   #28 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Clogged/burned cat could cause serious loss of power, overheating, etc..
Disconnect your exhaust before the cat, fire it up, and rev'er up a bit... see if it stops that from happening.
If it does, remove the cat completely, and shine a light through it. You should be able to faintly see light at the other end. Do it in a dark place, so you'll see better. Shake the cat while it's off... if anything rattles, it's bad, unless the rattling noise is just the heat shield.
