Old 06-17-2009, 01:50 AM   #5 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Hello -
It would probably be really hard to do, but it sounds like this is programmed into the ECU/PCM. In a perfect world, you would be able to REprogram the ECU/PCM to obey your shifting demands. I would make the only restriction to be based on the "minimum safe idle rpm", i.e. something like this :
Code:
new_drive_ratio = get_drive_ratio_from_shift_request( shift_up);
new_rpm = rpm_equation_from (  new_drive_ratio, current_mph, current_LOD);
if ( new_rpm > minimum_safe_idle_rpm )
{ // then
    shift_gears( shift_up);
else
    ignore_driver_request();
CarloSW2
American Solar Energy Society
