Originally Posted by beatr911
...Check for leakage so that all the air that passes through the hole actually goes through the radiator...
Coroplast under trays next? BTW coroplast can be ordered in black. When the paint begins to chip off you may consider this as a more permanent solution. I am.
I have installed some coroplast 'boxing' around the radiator, but I do need to go back and basjoos the heck out of it.
Yup, undertray is the next big mod. I've heard that the black coroplast is 'softer' than the other colors, so I'll stick with white. Can't see it under the car, anyway.
For the smaller stuff, I'm using from my Rensburger stash. Haven't even made a dent in it yet. If anyone is traveling through northern Indiana and needs a couple pieces, let me know.
