Old 06-19-2009, 12:08 PM   #10 (permalink)
LeanBurninating
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Civic HX
90 day: 44.37 mpg (US)
Originally Posted by bgd73 View Post
that is a good idea..although, if late model enough, is there a means to hack maf sensor or other thermal sensor? could be as simple as finding on the intake to wrap to stay warm..or wherever it is.
Im sure there is a way to fool the sensors, and I don't know all the intricacies of how lean burn works, but I am pretty sure that lean burn engages only when it does because its safe to do so.
In other words if you fool the sensors into putting the motor into lean burn mode when it normally would not, you could be damaging things.
