Old 06-19-2009, 12:12 PM   #11 (permalink)
DonR
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
Tee a heat riser pipe from exhaust manifold heat shield, or from behind the radiator into the intake infront of the filter. A butterfly valve on either the hot or cold side can be used to control temps. Carbed cars used a bi-metal thermostat controled, vaccum operated valve. But if you want you can use a TOGGLE SWITCH to control an electric solenoid to open & control the valve.
You could use the exhaust heat as the continuous heat & the electric heater for instaneous heat.
