Old 06-19-2009, 10:29 PM   #134 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
The scangauge doesn't actually shut off. I do have it in hybrid mode. Its just that the OBDII port doesn't see sensor readings until the computer reboots. So, it assumes I'm getting the same mileage as when I turned the car off.
This morning, when I took the charger off the battery, I jumped in the car, activated the scangauge, and it read 12.6V. I had checked while it was on the charger, and it said 13.2V just as it should. I guess I'll just live with the battery being low for now. I threw it on the desulfator. We'll see if it helps at all over the weekend.
