Old 06-22-2009, 02:09 PM   #25 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Well, yes, you want to neck down far before the throttle body. You want a smaller pipe connected to the throttle body for increased low rpm torque, and you want to adjust its length to play with the torque a bit too. But, before that, just use a large pipe. I don't see any problems with using aluminum dryer ducting like others have.
