Old 06-22-2009, 02:28 PM   #26 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by LeanBurninating View Post
... although you assume it will be run continuously...
I did no such thing, sheesh. If you want to run the thing it will cost you 4hp while it is running, is that better?
and you do not account for the decreased amount of time spent out of closed loop on cold start, as well as time spent in and out of lean burn.
I suppose if you want to argue that doing a long smokey burnout coming out of your driveway also shortens "out of closed loop" time, for a net efficiency gain then I would like to see that bit of figuring too
Seriously, 4hp is a huge deficit to overcome in efficiency terms.
