Old 06-22-2009, 07:00 PM   #27 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
bkeese: thanks very much for posting that info. It may help me when I finally get around to looking into this again.
Other new info I've learned since my 2nd unit failed (which I still haven't fixed/replaced):
- if the unit isn't receiving a high enough voltage, it won't work properly (one owner told me he fixed his by bypassing the brake cancel switch and wired power directly to the unit - with obvious safety implications). He did this after measuring the voltage at the unit and seeing there was a noticeable voltage drop when wired to the brake light circuit.
- the tech I spoke to told me the unit would work more reliably using a VSS signal instead of the coil signal (which is what I'm currently using)
