Old 06-22-2009, 10:29 PM   #1 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Tested: power draw of Geo Metro accessories & systems (volts, current/amps, watts)
Inspired by Tim's own investigation of his Paseo ... and his constant, incessant bugging me about how much power I thought it took from the battery and/or alternator to run my Pontiac Firefly (Geo Metro)...
Some good to know basic research. I was genuinely surprised how little power it takes to run the engine (no accessories on).
Voltage measured at the battery. Amps measured in a jury-rigged circuit with a multimeter inside the car. Volts x Amps = Watts.
To start the engine for the engine-on readings without blowing the 10A fuses in the multimeter, I roll started it.
Code:
Watts ... item
1.7   key @ ACC, ECU awake
17.8   key @ RUN, fuel pump finished priming
54      parking lights, dash lights high
59      brake lights
112     headlights, dash lights high
120     headlights high beam, dash lights high
36      key @ RUN (fuel pump running - priming)
6       radio low vol
18      radio high vol
96      radiator fan high
30      heater fan low speed (1)
49      heater fan 2
66      heater fan 3
81      heater fan high (4)
58      rear defrost
5       interior light
36      wipers low
53      wipers high
66      cigarette lighter
78      hazard lights (est)
42      horn (est.)
39      reverse lights
60      engine idling @ 880 RPM (alternator disconnected)
62      engine running @ 2500 RPM (no alt)
92      engine idling @ 880 RPM, alternator on (field current is high, topping up battery)
89      engine running @ 2500 RPM, alternator on - lower field current as battery voltage came up
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
robertwb70 (05-03-2011), Ryland (12-03-2011), wikityler (08-14-2009)
