Old 06-23-2009, 12:57 PM   #3 (permalink)
truckncycle
Bandit 600 - '96 Bandit 600
90 day: 40.71 mpg (US)
Ranger 3L - '99 Ranger XLT
90 day: 18.72 mpg (US)
I have a garage door that faces the same direction. I slid rigid insulation into the back and then fastened it in place with foil tape. The foil tape stuck to the metal but eventually failed to hold on the foam. I think you might have the same problem with the foil tape. It may be worth a try anyway. What about high temp silicone adhesive?
