Old 06-23-2009, 12:20 PM   #17 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by MazdaMatt View Post
Here's an idea...
A 1-axis accelerometer with analog output tied to a comparitor with potentiometer adjustment connected to a relay in parallel with the brake light circuit.
In normal human-speak, a circuit that turns on your brake lights at a particular level of deceleration, regardless of that deceleration being caused by your brakes or your engine or a wall.
Sounds a lot like a Tekonsha Prodigy trailer brake controller, it uses some nice accelerometer technology. Don't know how much an accelerometer costs which may be cheaper. Only thing is you would have to leave it on all the time which might drain your battery if you connect it to constant 12v to use with EOC. Or maybe connect it to a timer that will leave it on longer than your longest EOC then shut off. If you don't EOC, then connect it switched with ignition and call it good.
Winter daily driver, parked most days right now
Summer daily driver
