For what it's worth, I found this on the internet:
The owner's manual for my 2003 Tracker indicates when towing 4 wheels down, to stop towing and run the Tracker engine for 5 minutes every 200 miles. Does anyone know if this is actually required?
This would indicate the tranny lube pump is run by the engine and you should be able to pulse and glide or coast to your heart's delight.
Check your manual.
