Old 06-24-2009, 10:30 AM   #2 (permalink)
dcb
Don't Panic
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Hmm, that could be annoying. You are using a standard prebuilt without any mods? Is it in a case?
Definately have a look at the heat thread Power and Heat considerations (enclosures, etc)
The only time I've seen one go into thermal shutdown is when I tried a fancy vfd display.
I would leave the display backlight off during the day for starters.
An external 8 volt regulator feeding the guino power is probably the most effective mod if that doesn't help.
But if you want to tap your dimmer wire, I can put some pics together to show how to hack the guino to use that (minor bit of soldering required).
"I kicked a giant mouse in the butt! Do I have to draw you a diagram?"
