Old 06-24-2009, 09:45 AM   #148 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
for a tach its much easier than that. just get a crank position sensor or cam position sensor off any late gas engine, or even an ABS sensor from the differential of a ford pickup. mount it so it detects the bolts on your crank sheave or water pump sheave, for a tach. or drive shaft bolts if you need speedo signal
The Following User Says Thank You to diesel_john For This Useful Post:
oldbeaver (08-20-2009)
