Old 06-25-2009, 12:00 PM   #5 (permalink)
Southcross
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
If you have a scangauge, engine loads of around 80% on average show the best results. This is usually around 1/2 to 3/4 throttle from my experience. I try to keep my rpms between 2000 and 3000, again an average that I have seen work. You can play around with the rpm range and load once you are comfortable with the new technique to see where you get the best mileage from your engine as they'll all be different. Using this technique gets you going fairly quick so you need to be careful not to go too crazy lest you find yourself using the brakes a lot (which negates any benefits you just gained). Try this out and see how it works for you.
I know this is an old OLD thread... I'm back searching/researching and since I too live at altitude, I thought this may be beneficial.
since I drive a pre-OBD car and I can not hook anything remotely like a ScanGauge up, can anyone confirm this acceleration technique?
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
