Old 06-26-2009, 02:17 AM   #36 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by hyperyaris View Post
Make sure yours does not already use a form of DFCO and save yourself grief. A Scanguage will read 9999 mpg in DFCO mode.
I've found that this isn't always the case.
From the Integra shop manual:
"During deceleration with the throttle valve closed, current to the fuel injectors is cut off to improve fuel economy at speeds over following rpm..."
Basically standard engines are 950 rpm U.S. and 1050 rpm Canada.
...but I don't get the 9999 mpg indicator (and never have in tons of rental cars). So anyway, I often downshift on exit ramps or up to lights if I have to stop unexpectedly.
You can generally see and feel the transmission/TC give a bump in revs right below the cutoff.
Modern fuel injection probably has it -- at least OBD-II, maybe earlier...
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
