I agree with roflwaffle, you want the largest amp hour battery that you can fit if you go with lead acid, or you will tend to fry your batteries and replace them by the end of the summer, lithium you want the highest discharge you can get, lead acid you want that too but you also want capacity unless you are drag racing.
something that is rated as a traction battery is going to be the best way to go.
