Ok. But consider this. Store hydrogen in a tank. Produce it at home using off peak electrical power. Feed it into your combustion chamber. If you run little enough of it, shouldn't you be able to push it through your engine unmodified? It should improve combustion, and add a bit of power as well.
-Steve
