Old 06-29-2009, 03:23 AM   #4 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
Originally Posted by jetta2.5L View Post
i know the last figure i saw E85 was like 15,000 BTUs under gas (dont quote me on it) so the power is lower but i plan to upgrade the spark plugs and new wires so the mpg should be close to same.
I don't mean to sound rude, but you need some education on this stuff my friend.
E85 is more like 40,000 BTU's / gallon under gasoline (110,000 vs 70,000).
Upgrading spark plugs and wires is not really going to do anything for you, unless your current hardware is worn out. The advantage of higher octane fuel is that you can increase the ignition timing, or increase boost pressure in a turbo car, for more power (more cylinder pressure) without detonation occurance. Higher octane fuels also burn less efficiently.
The only good thing about E85 is that its american made and reduces the dependence on imported oil. If we could produce it efficiently and in mass quantities, it would be great. But we have already proved that we cant without significantly increasing the price of corn.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
