Old 06-30-2009, 10:10 PM   #5 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Soldering Iron, with blade attachment. The "blade" is actually an x-acto blade. Most soldering irons with screw-in tips will accept the screw piece from the good x-acto knives, so you can use a razor blade with a soldering iron, and make thin, shallow cuts until you get through it all the way.
Also, you can just use a fine hand file. Drill a hole to start from, then file your way around the thing. Fine metal hacksaw, wire rope, coping saw, etc.
You can also use a "hot wire" as well, but it will take some time, and you'll need air circulation depending on what type of plastic it is.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
