Old 07-01-2009, 06:13 PM   #3 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
IMO autos are tricky. Its easy to pin LOD where ever you want with a manual trans, but with an auto you have to learn to balance things. You don't want to loose a ton through the torque converter by loading it up too much. But, you don't want to loose a ton to pumping losses either. You really just gotta play with it until you find what you think works best. Using LOD should definitely help with that.
